Raul_C4
Hello ,
I am rebuilding my engine block , but for some reason when i purchased the recommended oil pan it was a 5qt pan and it didnt fit so i tried using a 6 qt pan and it was just under the right size so im pretty certain a 7qt pan will do the trick , but i am just confused on why the stock pan will not fit ?!!?! my crank is the same size and its a onepiece rear main seal and also the metal protector sheet that goes in between the oil pump screen and crankshaft was used when i took it apart so im using it again .
will a 7qt pan still work if i only use 5qt of oil ???
im just completely stumped and any advice will be greatly appreciated .
Thank you .
Thank you .
