CGM's1988vette
I’m need to pull my 1988 C4 engine which has a manual trans. Any advise on:
1) Pull engine alone or pull 4+3 manual trans all together? Can the engine slide forward enough to disengage from manual trans or do I need to first drop the manual trans?
2) Can I lift the engine by two bolts into the ends of the aluminum cylinder head or do I need to go into the cast iron block?
3) Can I pull it from the side or do I need to remove the hood and pull from the front?
