Joe Carideo
New member
The engine starts immediately and the car runs perfectly (55,000 miles). When the engine warms(after about two miles ) it will stall. It is starving for fuel. It will not re-start. It turns over but will not start. If you wait an hour when it cools it will start immediately and run through the same process. The water pump has been replaced. All injecters have been checked all OK. Cooling sensor has been replaced. It has good pulse and good spark. Fuel filter has been replaced. Everything seems to be in order. Any suggestions?
