Question: 1992 lt 1 problem with asr
tmkassin
Macomb,MI
2009 LS3
;shrugHI, I am trying to fix the problem causing my service asr light to illuminate. It seems that my ccm and ecu are not talking to each other. Also my sys light flashes. This causes the ecu to shut down the fuel flow. Ok the FSM on page 8D-15 at the top of the page shows a terminal "S222" that connects all this together. After trying several other fixes I am thinking this terminal is loose...but the friggin service manual doesn't say where it is located. Does anybody know where it is? Thanks;help
'S' is a common feed. I think it stands for 'splice'. Go to Vol 2, Sec8A, subsec 50, page 1 or 2. It will give you the location of the splice.
I don't think you need to go there tho'...
Edit:
Diags for ECM / CCM / ABS / Derm ('94 up) module com's failure are at the end of subsection 50 or 51
