1992 Valve Train Noise
jwevans
New member
Holly Springs, NC
1992 C4 Base
Hello everyone, hope you're doing well. I have a 1992 Corvette (LT1) that started making a ticking noise a few days ago. I went ahead and changed the oil, which was clean, but it did not help the noise. Below I attached 2 videos of the noise, both at 190 F. In the first video, the noise is very audible from outside of the car. The second video I attempted to film the noise from inside the car, as from the inside it sounds more like a clanking or thumping noise. It is not very audible over my exhaust, but you can hear it the most in the video in second gear.
First video, outside of car
Second Video, inside car (recommend high volume)
Right now, I plan on doing another oil change to inspect the oil and oil filter for metal shavings. I also saw on an old thread that someone recommended using a half quart of ATF mixed into my oil for 100 miles to flush the system, then change oil again. What are yalls thoughts on this? Any suggestions/guidance would be much appreciated.
Thanks!
Welcome to the CAC.
That first video sounds very much like a loose rocker arm. If you have a piece of hose or even a broom stick, put it to your ear and run the other end along the valve covers to determine which side it's on. It should be very audible. Next step would be to remove that valve cover and look for the loose rocker. It could be a bad lifter, bent push rod, loose rocker stud or even a bad rocker arm. On the more extreme side, there might be a bad lobe on the camshaft. You might get lucky and just the adjustment nut came loose.
Tom
1992 Vettes were also known for fuel line hammer - when the injectors open and close, it creates a pressure pulse in the fuel line which causes the line to tap against the mounts. I'd check that also.
Thanks!
Thanks!
Welcome to the CAC.
Tom
Update: I took off the valve cover like you suggested and was very surprised. I'll attach pictures and videos of course, but I discovered that I have aftermarket rockers that are bigger and smacking the top of my stock valve covers. I am going to order deeper valve covers and replace the gaskets while im at it, but wanted to know what you think? Also, I bought this car thinking it was stock other than exhaust so I have no idea what has been done other than rockers and injectors (which I just now discovered). Maybe a moderate cam but to me it doesnt really sound like it. Thank you very much for the help and I'll update again once I get my new valve covers.
Sounds like the noise went away with the valve cover off. It also looks like they have been hitting the valve cover. Do you have any noticeably loose rockers or rocker studs?
No, passenger side all seemed good but I'll have to check the driver side as well when I get my new covers.
