alfonsi4
Active member
HI,
I have had information that seems to conflict about replacing the antenna mast.
One says you have to take l/r Quarter and interior coverings to get to the antenna.
The other says it is a 5 minute job to do just the mast and pull cable.
My motor (by sound) continues to work, but the antenna does not go down. I assume it is because the plastic pull chain is stripped or broken and a new "mast only" should fix it.
Which method is more correct?
Any feedback is appreciated!
