Dellboy
This car was backed into at about 5mph with very minimal damage to the rear bumper, however now the dic is giving the following codes
PCM
P1626 Theft Deterrent System Fuel Enable Circuit
TCS
U1016 Loss of communicatiocs with PCM
U1301 Class 2 Circuit Shorted to Battery
BCM
U1016 Loss of Communications with PCM
U1096 Loss of communications with IPC
U1255 Serial Data Line Malfunction
IPC
U1016 Loss of communications with PCM
U1040 Loss of communications with TCS
U1064 Loss of communications with BCM
U1160 Loss of communications with LDCM
U1176 Loss of communications with RFA
U1255 Serial data line malfunction
U1088
BO-RFA
The battery is new and I have checked for loose wires in the bcm.
Any help would be greatly appreciated
PCM
TCS
BCM
IPC
U1088
BO-RFA
