Blu Cah
What is the easiest way to remove the drivers side headlight motor?
I'm getting a loud noise for about 5 seconds after the headlight is lowered (sounds like an A10 gattling gun going off).
From what I've read so far, it sounds like the plastic gear has become stripped.
I will be placing an order tonight for the brass gear replacement kit, but in the meantime I would like to rotate the gear 180 degrees to see if the problem goes away.
Also, I need to remove the motor to determine what type of motor that I have installed to determinre the right kit to buy.
Here is the link that I was steered to.
http://rodneydickman.com/corvette.html
Is this guy reputable?
