Irv
Since we've moved to Oregon from SoCal, on hot days with the A/C running, my '03 Z06 sometimes exhibits some significant spark knock under mid-rpm acceleration. This isn't the "light pinging" stuff, this sounds like marbles in the bores. That can't be good for valves and piston tops. Somewhat surprising since premium is 92 octane here, versus 91 in CA. Turning off the A/C helps. No discernable knocking when it's cool.
I searched the internet and threads on this and various boards and found there's an alternate ECM calibration (part number 9358673) to reduce spark knock. I made an appointment to have my nearest dealer install it, and when I got there they recommended against the update for two reasons. First, they said they applied one of these anti-knock calibrations to another vette (unspecified year and model) and the owner noticed a power deficit all of the time, though the knocking went away. Second, the owner wanted to undo the calibration and found you can't undo - the ECM has to be sent back to GM for a refit.
Another dealer, the biggest Corvette dealer in Portland (though nothing to shout about on a national scale) says they've heard no complaints about recalibrations, but couldn't say if they've ever done this particular one. So now I'm confused about what to do.
Has anyone on this board with an '02-'04 Z06 has the recalibration for spark knock done? If so, what's your experience with it? Can dyno-tuning shops help cure this knocking, for a custom solution?
