knoppphil
New member
I have a 2006 convertible which I stored from mid Nov to late Apr. The first time I attempted to start I had to jump. I was able to bring the power roof down, but ever since I have not been able to bring the roof back up. I had to jump start the car a 2nd time, but since it has started OK. I have found nothing in the manual to address this problem, and have attempted to call multiple Chevy dealers who’s response has been read the manual or bring the car into service. My sense is this is not major issue which I should be able to handle myself if someone could provide some thoughts as to steps.
I do not see any fuses in the instrument panel box which refer to convertible top. I only see two fuses which are labeled as tonneau release and wondering this could be possibility.
I am looking for expertise from the action center if possible.
Thank you
Phil Knopp
Thank you
Phil Knopp
I'm assuming here that this is your first year with your Corvette. I do not have a convertible, so I can't address your problem directly. But I will say that these cars are very dependent on the electrical system. Off the top of my head, I would say, check the battery for proper charge, drain, voltage....etc. If it is out of spec in any way, shape or form, replace with a battery that is up to specs. Check out the owners manual for the correct battery. Keep us posted on what you find.
