K
kpauley
I'm having an electrical issue which is troubling me. This car is new to me, have had it for a month, so I don't have a lot of history with it.
I got stranded a few weeks back, had to be towed. Car was running fine, backed out of a parking spot, turned on the headlights (they were down, hadn't rolled them up yet) and the car died. All power was gone. After towing it home and tracing down a bunch of wires I pulled off the cable in the engine compartment that connects to the back of the fuse panel on the firewall (there are two, this was the left one if you are standing in front of the car facing it). One of the lower connectors looked a little bent and like it had seen some heat. I plugged it back in and all the power came on. I figured I would replace that harness soon and thought I found the problem.
Well, it died again. Something seems to be shorting out. Symptoms are when you turn the key on (not to the ACC side, the ON side) the interior lights will all go out and all power is gone. Sounds like a short in the ignition circuit. Power slowly will come back on if you wait, I think. Or some of the pushing around of wires brings it back. I thought it was the ignition switch itself, still could be I guess. I'm also suspecting the voltage regulator.
Previous owner installed an MSD ignition in this car, I am not too familiar with that and I'm afraid that will make the diagnostics more troublesome.
A couple questions for all of you:
1: Any ideas based on what you are hearing?
2: Suggested diagnostic techniques?
3: Tips for removing the voltage regulator? Currently it seems like a two person job because the rubber bushings that it screws into are spinning on me, so I think I need to get under there with pliers to hold the back end while someone else removes the bolt.
