Just got my 82 back on the road. I had a surging problem and found a stuck IAC. Had an extra set so changed it out. Surging stopped and the car started and ran fine except for being very loud. Come to find out my daughter lost a muffler. No big deal since I needed to change the rear pipe anyway. Went looking for the muffler where she thought it came off. This is when I realized the car wasn't shifting right. Seems like when I tried shifting manually (1,2,3,D) nothing happened. Put in neutral and it stayed in drive. Came to a complete stop and it only shifted into 2nd. Pulled back into the driveway and tried backing back out after checking the cables and the car would only go into some forward gear no matter where the shifter was. Checked cables TV and shifter cables they are both intact and moving and I believe they are adjusted right, since it was working fine for the last 25000 miles.
The only change from when I drove it the other day was the lost muffler and the changed IAC. Could my changing the IAC have affected the transmission? If not what could cause nothing but forward gears in every position except PARK? The trans was working fine no slippage or other problems outside of a few minor leaks.
