84 Coupe - Rear spindle nut removal
AussieCorvetteNut
Gold Coast Australia
1984 Two-tone Blue Coupe
Hi Guys,
I have an 84 coupe that I am trying to remove the rear spindle nuts from.
Now normally you would crack this nut before you remove the spindle knuckle assembly from the car, but I have removed the rear suspension and driveline to panel beat the floor where past fellas have bent it by using hydraulic jacks in the wrong lifting areas, and I am repainting the floors and transmission tunnel.
Just after tips on stopping the spindle from moving in the assembly and getting the 36mm nut off. I know they are torqued to 175 ft-lbs.
I have already broken one of the Girlock cast assemblies (knuckle is ok), but I have a spare.
As long as I can get both spindle nuts loose, I can take care of the rest with a T55 Torx and my hydraulic press.
Appreciate the help.
Cheers
Tony
Update - Probkem solved.
Hi guys,
Just wanted to give an update on my spindle nut removal problem.
I took them down to the local mechanic and he lent on them with a 3/4 breaker bar, then a bigger air gun and finally got the gas axe out and heated them...problem solved.
Since the boys got the job sorted, I have cleaned them, used an etch primer and painted the non machine faces.
Came up looking great...well I think so anyway.
"gas axe"?
:chuckle
Here in the States we call it the flaming hack saw.
Specialised Spindle Nut Tool
Hi everyone.
Just wanted to share my new tool for torquing up the rear spindle nuts.
I purchased an aftermarket steel rim, don't worry it is a faulty/ 2nds rim, and used it to weld up a specialised jig for the rear wheel bearing assemblies or the rear spindle nut.
Now you could do these on the car, but what if you can't, then it's a large vice.
Check this out...works great,
"gas axe"?
:chuckle
Hib, out here in Chicago we call it the "Hot Wrench." A little different vernacular, but means the same thing. :cool!:
We called them a Heat Wrench when I was young. Regardless, it's a tool well worth having if you have the space and can store it safely.
