greetings,
I have a question if I may ask.
I have an 88 vette and want to be sure my vats system doesn't crap out on me some time in the future. in the past day or so, I have be not able to start the vehicle due to the vats system as so my code reader and scanner have told me. i either waited the 4minutes or so or, disconnected the battery for less than 30 seconds and away i went. while i am aware that there could be many causes for this such as dirty or worn key/lock cylinder, i want to play it safe as not to get stranded.
I have measured the resistor pellet across two on my ignition keys and have 2 different values.the first being 4.75 k ohms and the other being 4.77 k ohms.
I have checked radio shack for these particular resistors and only find the 4.7k (being short the additional 500 ohms). how critical is the variance in the resistor pellet resistance? yes, i know i could series connect the additional resistance but, would rather not do that if i did not have to.
do I need to get a "precision" resistor to substitute in the vats system?
next question,...
what is the best way to clean the internal contacts of the lock cylinder without "insulating" the contacts from the pellet on key insertion due to "cleaner residue" which may change the resistive value the computer vat system reads when you want to start the car?
.....thanks again!
next question,...
.....thanks again!
