Help! "89 fuel pump/sender removal
LORR1943
HOUSTON,TEXAS
1987 BRIGHT RED CONVERTABLE,RED & BLACK INTERIOR,
I read somewhere that the sender/pump could be removed through the fuel filler door. Is that correct? My shop manual says pull tank. This is a vert.
Thanks!
vetteoz
Not in Kansa anymore
Remove the fuel filler door and the rubber boot around the filler.Disconnect hoses to unit .The pump / sender assembly is held into top of tank with 10? bolts.
Undo these and lift unit straight out.Buy a new gasket
LORR1943
HOUSTON,TEXAS
Thanks ever so much! I was hoping that's what i could do.
LORR1943
HOUSTON,TEXAS
Awesome write-up. Another thanks to you!
aklim
Hartford, WI
91 White Coupe
Thanks!
Is this a Factory Shop manual or an aftermarket one?
T.M.808
honolulu
02 6 speed stage 2 clutch... 19"'mayas... 3"'drop
just changed my fuel pump the other day. Took about 30 mins. Make sure you change the strainer too.
LORR1943
HOUSTON,TEXAS
Got new one coming with gasket and filler(rubber). Thanks!
T.M.808
honolulu
I just got mine from napa. Don't forget the strainer. It does not come with the pump and is a must to change.
LORR1943
HOUSTON,TEXAS
Thanks to you all! Just finished putting it all back, everything works great. Gauge now reads correctly and moves. with the new filler it looks good too!
aklim
Hartford, WI
91 White Coupe
So what was the answer? Surely the filter had no effect on the gauge.
