92BlackVette
- Joined
- Nov 19, 2008
- Messages
- 211
- Location
- Austin, TX
- Corvette
- 1976 Black, 1992 Black coupe , 2003 Black Z06
152,000 Miles - No new changes - Almost all OEM
Condition: Engine shakes, and feels rough, not noticeable when cold or <100 degrees F
1.) Checked Ohms on Fuel Injectors: 23,23,23,23,24,23,23,24
2.) Fuel pressure 40 lbs static, > 42 lbs dynamic (increases with throttle)
3.) No Codes / Hyper-chip ThemoMaster Power Chip <-- 50K miles on it
4.) No arcing on wires at night, Spark plugs - not removed
5.) RPMS do not lobe at idle, they are 100% consistent at 700 RPMs
6.) At Highway speeds there are no noticeable problems (700 -2.5K RPMS).
7.) Spark plugs/wires changed 52K miles ago, Bosch (Platinum) type.
8.) Started 3 days ago, and the engine never dies.
9.) With Engine turned off, it takes 10 minutes to drop to 30 lbs of fuel pressure
10.) Coil, Optispark are 100% OEM
11.) The tone of the exhaust changed around the time the rough idle condition started. I run no mufflers and always have, so I am use to the "not hearing a cell phone issue" inside the cab with this setup. The tone changed, and I can tell; I drive this car daily! The best way to explain it, is it went from a Corvette with no mufflers sound (cut offs), to a 2006 Dodge Ram 5.7 exhaust tone, or a LT1 Corvette w/ no cats, no resonator, and no mufflers exhaust tone. - No exhaust sounds or rattling from cats. This is only noticed when RPMS are between 1.5K - 3K RPMS, not during idle
12.) There is a noticeable smell of gas from the exhaust, like it is running too rich, but that has been going on for longer then 3 days, more like 6 months.
13.) Fuel regulator diaphragm shows no traces of gas, nor do any vacuum hose on the right bank
*As you can tell I have been searching the forum---->;help
