bucket
On my 93 after I throughly cleaned the egr and was satisfied it was not malfunctioning I then ran the diagnostics from the fsm I have for the egr vacuum solenoid and found it to be bad. New part installed and the car ran much different because the vacuum was allowed to make the egr function correctly. And while I have mentioned vacuum check all the hoses and connectors for cracks or leaks with the mileage and age of the car it is possible you simply have a vacuum problem. I picked up about 3 feet of different size vacuum hose and then jumped around the vacuum hoses on the car one at a time until I found the ones that were leaking The first time I jumped the throttle after that I thought I had added 100 HP to the car.
nice car
