93 Ruby Red Front interior courtesy lights
George B
Meriden, CT
1993 Ruby Red
The front courtesy lights, on the bottom of the rear view mirror and those that light up the floor do not work when I open the door. I've checked both sets of fuse boxes, the main fuse box in the cabin, and the maxi fuses near the battery and the fuses appear to be intact. Just as the manual indicates. The courtesy lights for the "boot" behind the drivers seat work. Is it possible all of these light bulbs are burnt out? I know someone on this site knows the answer :D
Thanks.
You have to check the courtesy lite fuses. There are two (2) of them in the cabin fuse block. Use a test lite and make sure they are good. Sometimes a fuse will "look" good and be blown.
The bulbs could all be burnt out. I highly doubt that scenario, tho.
SAVE THE :w
Torque Shop
Dream Giveaway
