scotth48
Having problems on my 1993 ruby with no courtesy lights. I am gettin power on both sides at the 5 amp fuse and on each lamp socket. Relay is ok. Was also getting power on white wire of light switch connector. When I grounded the white wire on the courtesy light socket the relay would buzz. I thought about disconnecting the white ground wires at each connector anreplacing it with a new wire to a ground of its own.
