94 C4 up grade wheels + tires what size?
  • Thread starter Thread starter boonie
B
boonie
i want to upgrade my wheels + tires for my 94 C4 from the current stock set up. i plan on buying sone ZR1 replica wheels from discount tire direct ( unless some body knows a cheaper outlet) the wheel size will be 17x9.5 so what the largest tire i can put on the front?
also should i go with the 17x11.0 on the rear or stick with the stock17x9.5? and what size tire would you reccommend here?
suspension wise the only changes iam making are replacing the OEM shocks with KYBs
thanks boonie
You can run 275s or 285s on the front, but i would stick with 275s. On the rear you can run 335s on 11"s, but I would run 315s.
And yes, i would get the 11"s if the price wasnt bad.
17 x 11 and 315's all the way around. Or 315's up front and 335's on the rear.
:cool :Steer
