compyelc4
- Joined
- May 1, 2002
- Messages
- 609
- Location
- Dayton, Ohio
- Corvette
- '95 LT1 Coupe, Comp Yell; C6 Roadster, Vel Yell
Leaking water pump. Book says nothing about removing power steering pump pulley but it looks like that is the only way to get to the short bolt on the drivers side of the water pump. Is this true?
If true, can someone tell me a simple way to remove the pulley? It looks like it may be fastened with a large allen-head bolt, but the book says I must use a special pulley remover to get it off, and then a special tool to reinstall it. Come on!!!
Any suggestions here?
I'll hold up on the process until I get the word from one of you.
As always, thanks in advance.
