96 LT1 Oil Pan Removal
Jakey1954
New member
Seattle, WA
1996 C4 Collector Edition, LT1
Hello,
Have a 96 CE AT and would like to know the easiest way to remove the oil pan.
Thanks.
compyelc4
Dayton, Ohio
'95 LT1 Coupe, Comp Yell; C6 Roadster, Vel Yell
Hello,
Thanks.
1. Drain oil
2. Remove alum flywheel cover
3. Remove starter.
4. Loosen rear muffler support at tail pipes, and support with blanket rolls.
5. Remove 2 sets spring-loaded exhaust "hangers".
6. Remove driver-side catalytic converter. May require you to move the left and right exhaust pipes rearward an inch or two.
7. Remove oil pan bolts, nuts, anti-knock sensor shields, and a few other misc. attachments.
8. Remove oil pan. You should have just enough front clearance between the bottom of the timing cover and the cross-brace to do this, especially if front crank bearings are in horizontal position. Mine were. I lucked out. If they are not then just turn front harmonic balancer/pulley using socket on large bolt that attaches the balancer/pulley to the front of the crank shaft. Don't worry, If you turn the bolt in a clockwise direction all will be okay as this is the direction the engine turns when running.
