Been doing high RPM with an elevated oil level in the engine? All that air swirling around in the bottom end can cause oil to spray/sling into the oil ventilation system. This vent line dumps into the air cleaner. That's how the oil gets there. The cure is to reduce your RPM's or install a "catch can" that effectively catches the oil droplets before they go to the air cleaner. But, you gotta empty that catch can often.
