A
AUSSIEVETTEMAN
Help, A few questions!
Hi everyone,
I have a few questions and am after a few tips for taking the drive shafts (input shaft and half shafts) out of my 81 Coupe. I have her sitting on car ramps at the moment and am wondering if there is anything I should be aware of before tackling the job?
I backed her up on the ramps this arvo, ready for when the parts shop opens tomorrow (Monday, your Sunday arvo), to pick up a Torx socket set to remove the uni bolts.
Will I have any 'dramas' undoing the clamps and taking out the shafts if she is up on ramps? I was going to put her up on stands, but feel ramps are a little safer. I thought about getting to the bolts on the diff uni and these shouldn't be a problem if I take the half shafts out first. Once the half shafts are removed, the input shaft should spin.
The reason I am removing them is because I want to balance them and even though I have replaced some of the uni's, this was done at a Diff place when the diff was rebuilt. The uni's that were put back in were greasable units and I can't guarantee quality. The balancing shop will pick this up once the shafts go on the balancer. They will put a good American brand in there for me if the others are cactus. This should get rid of the slight vibration I have in the driveline area, if not this maybe rear wheel bearings, but these are only 3 years old and the vibration is coming from the driveline, you can feel it.
I had a vibration in the front, but new wheel bearings in this area fixed most of this problem, there is still a slight vibration there, which I think is coming from either the front disc as it has a large groove in it or it could be the tyres, which could have a slight feathering effect caused by the wheel bearing not running true.
Any tips?
Cheers
Tony
Hi everyone,
Any tips?
Cheers
Tony
