Friday( and rest of weekend ) plan
Not in logical order
Steam clean!!!!!!!! EVERYTHING..
Maybe pull rear end out & replace nose seal & replace C clips for yokes, re do rear cover gasket.
Drill, tap & Helicoil the rear end diff mounts
(for spring) replace ALL rear end hardware & rubber.
Inspection cover for flywheel.
Starter rear hanger bracket.
Fix fuel leak @ tank feed ( old hose )
Rear shocks.
Center steering wheel.
Dis assemble electric fan & lube it
( bearing death squeeks)
Install Petronix/MSD6A & coil
NEW PLUGS
Clean, inspect & re route plug wires.
Remove tach cable, clean & lube ( again ).
Replace front sway bar hardware & bushings.
Replace ALL ( rubber) fuel lines & filters.
Front shocks
( If Mid America delivers on time )
Fix door locks ( really FUNKY feeling).
Drivers side door..
Sounds like a ton of LOOSE stuff in there.
Clean & adjust E brake & E brake indicator switch.
Lube heater cables & linkage
Rebuild & re jet carb.. it's a 750( 3310-2)Vac secondaries with 72's in the primaries.. starting @65 and will work UP.
Valve stem seals.
Rebuild power steering ram.
New water pump.
New belts.
Squirters for wipers ( not working).
Fix right turn signal indicator in dash.
Inspect brakes.
Balance tires.
This SHOULD make the car streetable.
Then back to clean & detail patrol.
Generate NEW lists.
Vig~
