markmark
Can anyone tell me where the trans fill hole is in an A4 2001 coupe?
Hi there,
Its a 22 mm fill plug on the side of the transmission pan.
You will need to check the level at the temperature of 80-122 F on the DIC>
Allthebest, c4c5
Thanks Paul. As you know I have been having trans issues with my coupe. After leveling the car out on jack stands, and being warmed up, I unscrewed that plug and fluid ran out. Didn't seem right. Thought I would ask about the plug, just in case I was missing something.
The drain hole is also the fill hole.
