Have you ever wanted to take a hammer and just start smashing windows and plenum and runners.
This is what I have did to the car and no start.
New fuel pump
New fuel filter
New fuel pressure regulator
New fuel relay
ohmed all injectors (16ohms)
took low amp bulb just to see if any pulse. (yes)
Fuel pressure is between 46lbs and 48lbs. Still drops off after I stop cranking. It never hits a lick. Use starter fluid and starts right up and dies.
I'm so lost and mad. I spent everthing I have on this car. Car ran perfect befor I tore it down for paint.
Should I hear the injectors when the key is turned on or while I crank. Thanks.
New fuel pump
New fuel filter
New fuel relay
