stevolwevol
My 79 rides just about 1/2 to 3/4" lower on the passenger side rear. Is it a good idea to raise the spring by turning the nut on the bolt that holds the spring? They are set exactly the same on each side which is almost to the end. If I did this, the passenger side would be turned in more than the driver's side. Is this a good way to even the rear out? Suggestions would be appreciated.
