BlackNBlue95
Re: Tranny
Condition:
2nd & 3rd gears only OR 1st and 4th Gears only
Inspect Component:
-Possible code 82 1-2 shift solenoid Circut Fault
-Shift Solenoids (379)
For Cause:
-Sediment
-Electrical Connection
Sounds like most possible cause is shift solenoid A is not functioning Thatis the 1-2 Shift solenoid.. gatherd that from reading the trouble shooting info above and looking at the apply chart for the trans..
Could be an elctrical problem such as a break/short in the wiring harnes from PCM to trans, a bad PCM driver (which could happen due to a voltage spike) or just a bad solenoid...
I would probably drop the pan and replace just the shift solenoid A and see what happens its the easiet thing to do at this point.. or I guess you could also hook up a voltmeterto the harness and see if you get voltage whith the engine on manual first or drive.. i would try this before someone says lets pull the trans.. much cheaper then spending 1500$ on a trans job when all you may need is a shift solenoid which is not uncommon because it's just a coil of wire that creates a manetic field..
Hope that helps any let me know if you have more questions.. I'm currently rebuilding my trans..
-Rick
Got to look at my service book here.. This is what is says for that condition..dabvette said:Thanks for the help, Rick. The car in starts in 3rd. I can manually put it in 2nd. I then have to manually shift it into 3rd. No 1st and no OD. I'm going to the tranny man Monday but it would be nice to have a Corvette technician give me a good idea of what could be wrong. Thanks again.
Chris
Condition:
Inspect Component:
For Cause:
-Sediment
-Rick
Pull the codes on your Vette´s money sensor. I think it missed your Christmas bonus. :confused Mine would never settle for a blown fuse when it could get the tranny pulled.
