another brake light question
o2bnkc
Carson City, Nv.
2002 M.Y. convertible
I've got a 65 with no brake lights on the passenger side. It originally had reverse lights but not now. Here is the setup:
Outer lights are running lights, turn signals, and brake lights.
Inner lights are turn signals and brake lights.
The running lights and turn signals work fine. The brake lights don't. I could sure use some help on this one. Thanks, Chris
LLC5
Wa.
98 black 6spd convert.
If your turn signal and brakes lights are the same element in the bulb as was OEM, then it is a bad turn signal switch. If your turn signals and brake lights are seperate bulb elements since the aftermarket work, then it might be wiring also.
o2bnkc
Carson City, Nv.
Thanks LLC5, it turned out to be the switch. I bent the little filiment around closer to that center post. It seems to work for now.
