cntrhub
- Joined
- Jun 17, 2002
- Messages
- 390
- Location
- North Hollywood, Ca.
- Corvette
- Miss my '62 & '80 4- Sp. Vettes
Looking at that photo, I see dry (or should I say "cooked") coolant at the Torx bolt. The position of the dry coolant looks to be at 3 o'clock, and then at about 6:30 all the way up to about 8 o'clock. The highest wet part is just about parallel with base of the Torx bolt looks like? So taking a guess, there would seem like a spray misting out the back at the base of the Torx. The spray looks to be about 11 o'cock, through 2 o'clock, according to that wide 'wet' spread. Then it travels down into that green puddle. Other variable could be the same leak out the back of the Torx straight down, filling the cavity, and evaporating, leaving the upper most area still wet.
Now, the question is.... was this a dealer or independent repair? Usually the dealer backs their work up a few months. If they use factory parts, then that is backed up by GM for I believe, 90 days for parts (only). Things may have changed at GM? So a phone call would be the next step as who did the repair, and what their guarantee is?
If there is no satisfaction for warranty repair, then I would remove the Torx bolt, goop the pipe sealer on the threads and hope for the best. Done with a dead cold engine repair for this job.
