M
		Moonunit 451
Went out today and my range guage read "0".  I usually keep it on range.  Two days ago it was around 345 with about 3/4 tank registering accurately.  All other lights and guages reading properly, until --- I flipped the switch to check my average gas milage, which I nornally leave on instant.  Now this read "0"!
I drove about 15 mi. and each one went up to 1, and .1 respectively. As I returned home, another 15 mi., the range went to 2 and the average to .3. :crazy
SO, these funtions, being controlled by sepearate toggles in different positions on error are the ONLY eroneous (?sp) readings :confused I consulted the manual (which I never do, cause, far as I can tell it's not written in english, unless you're a certified GM tech), from what I could determine, I'm supposed to perform the UNSPECIFIED Test Q
 Test Q
Experience tells me that I should D/C the battery and reset the computer and hope it goes away, BUT, it also tells me that there are some readings developing, but they are not correct. The computer should have reflected my driving MPG and range MUCH more accurately in the distance I traveled.
So I thought I'd throw it out here before I do anything. Cars running good. Thanks in advance folks
 Test Q
 Test Q
		 all the sudden i drive along and instang mpg goes from 25 (at which the throttle in OD cruising) or so to 0 and slowly go back to the same setting at the same throttle position. this is really throwing me off since the car is running really rich right now and throwing a code (just started) and it's showing like 7-12 mpg on average :L i know it's not running that rich. my OD and Shift light sometimes flashes on and off now also. would be cool if it was rigged as a Real shift light!
 all the sudden i drive along and instang mpg goes from 25 (at which the throttle in OD cruising) or so to 0 and slowly go back to the same setting at the same throttle position. this is really throwing me off since the car is running really rich right now and throwing a code (just started) and it's showing like 7-12 mpg on average :L i know it's not running that rich. my OD and Shift light sometimes flashes on and off now also. would be cool if it was rigged as a Real shift light!  guess i'll be looking for someone to repair this when it starts blinking the whole dash out :L
