Anyone have this problem?
JT ZR-Won
Bradenton, FL
'90 ZR-1 #3010
I had the car out for a bit the other day and was cruising around with the "ventmaster" installed on the rear window. When I parked the car in the garage and removed the ventmaster, I noticed that the lights would not turn off inside the car after I closed the glass. The window is totally closed but it seems that the mechanism for the lights that pushes downward moved a little. Just wondering if anyone had that problem.......kinda took me by surprise. Guess I'll have to take it apart to see what's going on in there. For now, I just leave the ventmaster thingy in the window because the lights turn off when that's installed.
Jay
S
Steel Half-Shafts
Jay,
I've seen that happen before. The ventmaster has bend the little "thingy" on the hatch light switch. You can bend it back easily.
Usually this happens when the part of the ventmaster that press down on the hatch switch is a little too long, which bends it down some and then won't switch off with the stock hatch pin. You will have to adjust or file that portion of your ventmaster down some.
Seen it happen alot with the 2 piece adjustable vent extenders.
D
Drewser
not to sound stupid or anything but
What the he!! is a ventmaster? Can you take a pix?
C
c4ever
Hey Drew,
It's a bracket you can get at any supplier(Ecklers,etc.). It keeps the hatch open a few inches for better air flow in the cab when driving but does not effect int. lights and alarm system. I gotta get one of those one of these days.;)
-=Jeff=-
Bartlett, IL. (Chicago Suburb)
1990 ZR-1
Steel Half-Shafts said:
Jay,
or look inside the piece that hits the light switch.. there is a screw in there to adjust for this very reason
JT ZR-Won
Bradenton, FL
'90 ZR-1 #3010
Cool.....Thanks Jeff.
Drew,
The piece is really worth getting. It allows there to be a lot less turbulence inside the car when you have both windows down at any driving speed. Works well at 130mph too:D
Jay
-=Jeff=-
1990 ZR-1
Drew,
Jay
Yep the vent master and the outside Mirror deflectors found on Verts are worthy mods
