Haven't used 'em yet, but will
Anything you can do to reduce friction (or, should you think of going to aluminum or lightweight steel rockers, reciprocating inertia) anywhere is a good deal. I don't have one of my Summit or Jeg's catalogs handy, but the PAW catalog lists their generic steel rollers at $90 and some aluminums at $150. That doesn't seem like much of a risk. Be aware some don't fit under all valve covers.
Another advantage to these is they are more rigid than the factory stamped ones. Just like good hardened pushrods and rocker arm stud girdles, added rigidity in a valve train is also a good thing.
Matching the intake to the cam you select may be more important than matching the head's intake runner volume. If you read between the lines on Edelbrock's popular Performer and Performer RPM head-cam-intake systems, the heads are in essense the same. The only difference being the Performer heads have provisions for exhaust gas crossover heating. The intakes and cams differ enormously however.
If you have the extra $125-200, I would definitely change intakes. Pick one that matches the RPM range you cam is aimed at. I'd avoid a big single plane type unless you're putting in a monster lift and overlap cam.
Remember too, if you pick a cam with enough lift, or enhance its lift with other than 1.5 ratio rockers, you could overwhelm your stock valve springs. Talk to a tech there about which one you are picking with what you have. It wouldn't be a bad idea to get those springs changed to a nice stiff set anyhow, if they're the originals, or do it yourself if you hate yourself.
If you don't change intakes now, at least it's top end so with a dozen bolts and lots of sealant you can easily later.
One thing you definitely want to change is your timing chain set. Go to a true double roller or gear driven deal (I have to try one of those noisy things!) You might get a cheapy two or three piece timing chain cover kit too so you don't have to disrupt the oil pan again to get to your cam.
Good luck with your cam change. I had great luck with one in an old Mopar a few years ago - a generic house-brand Summit or PAW if I recall. I never could believe such a tiny engine could put out that much power. As soon as I get my overdrive decided on and in, I'll be doing the same.
