tpivette89
Active member
last month i baselined my current combo several times at our local track. best timeslip read:
13.16 at 103.79 w 1.76 60ft
since then i had some problems with my car that resulted in the replacing of the MAF sensor. that set me back about a month. so after i fixed the car, i installed the crank pulley and went back down to the strip today. weather conditions were nearly identical. only one major thing differed between my 13.16 run and todays passes... i ran on street tires this time, when last month i was on DRs. dont ask, its a long story.
anyway, even with limited traction i was still managing to 60ft halfway decent. so while my E/Ts werent availible for comparison, my mph (the TRUE indicator of a power increase) was. i only got 2 runs in this morning:
13.94 at 104.37 w 2.29 60ft
and
13.22 at 104.73 w 1.86 60ft
so, as you can see with the solid increase in mph, i gained about 10hp from the crank pulley. if i had my DRs on at the time, and 60 footing where i normally do, i believe i could have pulled off a 12 sec pass at 105mph. oh well, theres always next week.
bottom line though... the crank pulley is a legit mod
and
