bwing
- Joined
- Oct 28, 2005
- Messages
- 517
- Location
- California
- Corvette
- 03 Z06,66 coupe(sold),99 Porsche Carrera(sold)
Can someone tell me what the battery voltage should read when the ignition key is just turned to "on" without starting the engine.
The DIC is reading: 11.3 volts. Should it be more?
I'm writing again because I first wrote that I was getting a dash message when I first turn on the ignition. It reads, "Remove Key, Wait 10 Secs". I've taken it to the dealer who thought it might be a security problem and I've heard from CAC members that it might be a low(bad) battery. I'm still getting the message but only occasionally. I think it could be an emergency problem if I ever had to start the car and drive off quickly. The way is it now, if that message pops up, the car will stall in less than 5 secs unless I turn the ignition off and wait. BTW, there is a loud click coming from the steering column when turning the key on then off and yes, the locking plate has been removed.
Thanks, Brian
Thanks, Brian
