Bolisk
I have a 1972 LS5, p/s, and a/c car. Needless to say, the v-belt routing is complex with the P/S pump, A/C compressor, and Alternator. . .all having their own belts. That said, I've noticed something on my car that I'm not sure is correct or ok.
In the top of the front cross member there is a large dimple where the crank/harmonic balancer pulley sits when the engine is in the car. Now in my configuration there are two belts that are driven directly off the lower crank/harmonic balancer pulley. One (the one closest to the back of the car) simply goes up and around the three channel water pump pulley with an idler helping to keep it tight. The next belt goes up and over the second channel on the water pump pulley, then it goes over to the PS pump and back down to the crank/harmonic balancer pulley.
Now when I want to remove these two belts. . .I have to remove the fan and the water pump after loosening the P/S pump and idler. I figured one I have done this, the belts would just fall off the lower pulley, and I could remove from from the lower pulley.
Turns out I cannot get the belts out of the car because there is not enough space between the front cross member and the bottom of the crank/harmonic balancer pulley. I actually have to remove the lower pulley as well in order to get the belts out!!! Is this normal? Anyone else have to do the same thing?
On closer inspection, the lower pulley is not in the middle of the dimple in the cross member. The pulley appears to be closer to the driver side of the dimple. . .and with the belts installed. . .the P/S belt is DAMN close to rubbing on the cross member. I can get a piece of paper to pass easily between the bottom of the belt and the cross member, but an index card rubs. . .when trying to get it to pass between the two.
It is possible that the engine is not mounted correct? Bad mounts? Missing spacers (if there are supposed to be some). . .
Regards!
Regards!
