Achilles
I took the door latch mechanism out of the passenger door on my 82 to do some adjustments. Everything worked fine after I put it all back in, door opened smoothly...untill I locked it!
Now the door won't unlock and I can't open the door. I've tried using the key and trying to pry levers with a screw driver. Still won't open.
I was able to pull the inside door panel off with the door closed...not easy.
From what I can tell, the lever that is the locking mechanism rocks up and down. This lever is not making the full movement upwards, which I assume would unlock the door.
Don't really know where to go from this here.
Any ideas?
ad
Any ideas?
ad
