Carmen, you are quite welcome. That's what these forums are for, so we can share ideas! The wandering problem I have heard is partly due to the GY run-flats. So I am switching to Michelin. I have heard they are alot better, quieter, and do not have that wandering tendecy. I beleive the shocks will help, but I also believe that the springs are softer and that contributes. I am not sure. So my thought is to change tires and shocks first (since I did the Z06 sway bars and links already) see what happens then decide on any spring changes if needed. This way I know what it actually was that made the change, again, if any. In Chuck's case,
he has the Z-51 setup from factory which means he has the Sachs monutube shocks, not Delphi as in FE-1, and the stiffer spring rates to match, which in my opinion is why he has not any ride quality issues, then with the Z-06 bars, even better. The FE-1 suspension is the one in question......
Herbie
