A1Avette79
'79 started making funny squeaking noises at different times from the rear end. At first i thought it might be shocks/springs but it doesn't seem to happen consistantly at obvious suspension times like hitting a bump or when i rock the car or push down on the back end. Sometimes it squeaks when i back up (with or without applying the brakes). It has started happening when going forward at slow speeds as well. I don't know if it happens at higher speeds - too much road noise. Brakes work well although i did have to add a small amount of fluid to the master cylinder last month. I can't see any signs of fluid leaks anywhere. No pulling to left or right during braking. No virbration in steering wheel. I replaced all four axel shaft U Joints about six months ago and all rubber bushings were replaced front and rear last year. I have not replaced Drive Shaft U Joint.
Can the parking brake make this type noise? I never use it except when working on the car on jack stands.
The car's maintenance records show that the calipers/pads were replaced before I bought it five years ago. The car was mostly garage kept with very little road time before I bought it. Since then I have driven it every day - mostly in stop and go traffic unfortunately. I've put 30K on it since I got it. Although the brakes work fine it would seems that they should be close to needing work. Could they be causing the noise?
If i replace the pads any suggestions on type. I see alot of different types online: Organic AC Delco, Semi metallic, Ferro Carbon etc. I don't race but as i said most of my driving is city stop and go. Pads range in price from $40 for a set of 4 to $180 for a set. Thats a big difference.
