- Thread starter
- #21
W
wolf_walker
Brill rotors? You mean drill out the rivits that hold them on? Baa, to $$$ for two minutes a wheel with a drill.
Otherwise it sounds about right. I'd do what I could at home, about what 77-4speed said, except I'd try the hard line replacement just for the heck of it.
And if you DO do all this at home, you can take the cash saved on labor and buy youself some rear bearing assemblies with the rotor already matched to them, problem solved, bolt them right into your t-arm and your set with the rear bearings which will go out just as soon as your done with the brakes, acording to Murphy's Law.
