- Thread starter
- #61
Pags
- Joined
- May 10, 2014
- Messages
- 56
Yea, it's a shame though that the bank is gonna sell the entire car for salvage for about 3k, when the engine and trans have about 25k invested in them.
One more thing, make sure that your battery cables are clean and tight. After cleaning and tightening the cable bolt, make sure that you cannot twist the cable ends back and forth by hand, sometimes the bolt can be tight and the cable is still loose on the battery terminal. Good luck with it.![]()
I wouldn't mind getting another 98 just to make it easier, but I'm afraid I'll run into the same issues down the road if I get another 98. If I can find all the schematics I'd be fine with swapping it out for a newer one. I think that would be best so I have some more versatility down the road.
No not replaced, but I did take it apart and cleaned all of the contact points inside
Tha is for the tip! I used a polishing wheel on my dremel to clean them. I do remember slight pitting on some of them as well. I'll definitely take your advice and replace it as soon as I get the car back from the body shop. I'd rather do that than spend un needed $$ on a new pcm and tune lol
