O
omega1940
I have an 1988, 4+3. My cruise control has failed. I believe I read that on possible problem was the vacuum damper valve leaking or not functioning.
I located the valve by following the vacuun hose from the cruise control servo to the valve. The black plastic valve has three vacuum tube connections. One comes from the cruise servo, and one comes out of the right rear of the plenium near the fuel pressure regulator. I bought a new valve anf when I started to attach the vacuum lines I could not locate the third vacuum line.
I have searched everywhere around the distrbutor and simply cannot find the hose. My Haines manual does not show any diagram if this damper valve.
If anyone has replaced this valve I would appreciate some help. I believe the line ftom the cruise control tube connects to the valve on the "L" shaped outlets on the bottom of the valve. The vacuum line from the plenium goes to the top outlet pipe. The 3rd outlet is the one I can't locate.
Also, any other trouble shooting ideas wolud be of great help
as well.
Thanks,
Mike Haselmire
as well.
Thanks,
Mike Haselmire
