Need technical assistance with my 86, recently it has developed an unstable idle, vary 300+/- rpm while in any gear postion. otherwise the engine performs perfectly, no driveability problems.
To fix this problem, I removed the throttle body, cleaned it thoroughtly, replaced the idle air control valve,with a new one, and visually check vacuum lines/hose.... still have same idle problem.
I'll greatly appreciate any help, and want to thank you in advance for your assistance.
Thom
Thom
