b757captain
New member
Greetings from the sandbox,
I just picked up an '04 freshly imported from the states. My first day of ownership ended with a barely running car, messages include reduced engine power, service traction control, service active handling, and a host of trouble codes. I pulled the codes (thanks to this site for that!) and the relevant ones seem to be 0120, 0220, and 1516.
Here's what happened: I drove the car home and stopped for gas and a wash. I thought the car wash would be safe (one of those gantry thingys where the car doesn't move, the washer does). While I'm sitting, jets of water start spraying up from underneath (to clean the undercarriage, presumably). I didn't know about the "auto bidet" until it was too late, but I can always remember that I have done stupider things in the past, and will do even stupider things in the future!! As I exited the station, all the above mentioned actions take place, and I can do maybe 30 mph tops. In UAE traffic this is like inviting a crowd to your impending funeral!
After researching (this site again!) I've come to the hopeful conclusion that maybe I've got a bad chassis ground. The codes all point to problems with the TPS and throttle pedal sensors, and since the old girl was running perfectly at first I can't see any relevance other than maybe water spray soaking the (TAC??) located under the battery.
I did check the interior fuse panel area and the carpet was damp, and I could see a small amount of moisture around the fuse panel, though not the computer next to it. I left everything open overnight to dry out, which it did. Now I can get 1600 RPM and a smooth idle (day before only 1100 and bad idle) but all warnings still present.
Another question/possibility: I have noticed over here that the gasoline has a much harsher and stronger smell, leading me to believe that the gas here is refined much differently. Since the troubles started just about as long as it takes for the fresh fuel to mix through the system, could this have had any bearing on my problems? I know the computer can detect high/low octane, but would "strange" gasoline cause any problems?
I'm off to the local dealer today to see just how far over I'm going to be bent, but can anyone offer any other insights?
Many thanks,
Mark
Many thanks,
Mark
