Best Vette Yet
I have a 2005 C6 Auto, 4800 miles. Purchased Sept, 08. Vette went great until battery died. Replaced battery. Since then, every fault code in the book appears. Service traction control, shocks inoperative,etc. windows will not close up after entry, drivers window rolls down 7/8 of the way. Vette will sometimes not start and the gauge cluster will go dark, then come up on its own. Check engine light comes on. When the car is running, on a good day, all is well until something like "traction control" is activated on a wet patch of road. At this point, all hell breaks loose, power is cut and I have to pull over and power down for 30 secs. The vette will not always start up again so I have to sit and press the dreaded button over and over again. I have had the vette in pieces, have checked nearly all the wiring, connections etc. I can find nothing loose or unusual. I do not drive it anymore for fear of being away from home and stuck in a mall lot. I use the key to open it up. I have replaced the batteries in the fobs as well. There are no mods on the car, everything is as is from the factory. I have PM'ed c4c5 so I am hoping for an answer soon. In my PM I said the car had done about 18K, I was mistakes, typo error. Any assistenace would be helpful. I have read other posts about starting problems but mine seems to be unique...just my luck eh. ad
