Andric Hays
New member
Hello all, I'm new to this forum and to the corvette world actually. i recently bought a used vette from a gent here in town hes a pretty straight shooter and told me about the problems he had with it. but i digress, the vette is a c6 and it cranks for a period of time that makes me cringe if you let it ride out the crank til it turns over. you can bypass this issue by either letting it crank for a short second and stopping it then pushing the button again (starts right up), then the other option is to press the button when i don't have the clutch depressed and i can hear the pump prime or purge or whatever it does, and the car will start right up. i have no issues driving it at all, although i did notice the engine right after start up it will have a idle similar to a carb car on a cold day (almost like the rpm's are going up then down and the car sounds it). but no noticeable stalling. any help would be greatly appreciated!!
I think, in order to help our troubleshooters, we need a little more information. The year, model (base/Z06), transmission (manual I'm guessing), mileage and modifications done, would probably help our guys some in determining your problem.
