cARB REBUILD OR REPLACE?
Jim B
Illinois
1974 L82 Grey coupe
HI GUYS,
HAD SEVERAL PROBLEMS WITH MY CARB. I'M GETTING TIRED OF PERFORMANCE ISSUES AND THE CAR DYING OUT. SHOULD I REBUILD MINE OR REPLACE IT.
Washington, Michigan
'67 Marina Blue Convertible
If it's original to the car, have it professionally rebuilt by someone who REALLY knows Q-Jets and has the right parts; don't just "throw a kit in it".
walkman
ca
1971 Stingray Bridgehampton Blue
I have used Jet Performance for a Holley in Ca. My q-jet needs rebuild allso, Ill check if they do them.
motorman
pa
2008 Crystal Red Tint Coat
HI GUYS,
try craig woodruff 330-799-3222 he is in youngstown ohio and runs the carbs on a engine before shipping. e mail carbking@aol.com
walkman
ca
Jet does it , they have web site. About $560
problemenko
NJ
1979 White/Black
I bought a rebuilt q-jet from Sean Murphey Induction in CA. He will jet per your specs, uses quality parts and quick delivery. The carb was around 350.00 to the door. Check out his web http://www.smicarburetor.com/
Jim B
Illinois
1974 L82 Grey coupe
Thanks guys, I'll look into your suggestions. I really want it done right. I'll let you know what happens. Jim
Evolution1980
Administrator
Cleveland, Ohio
ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
does he put them on a engine just to check to be sure that the mechanicals are working? 'cause I don't see how he can assume it's tuned correctly if it's not on a similiar motor to which it's being mounted. ???
