casting numbers
6925jason
queensland
Can anyone help me I have a c3 and am trying to identify the block, casting no. 4010207 and the cylinder heads are 333882 any info would be appreciated.
Jason, first off Welcome to CAC. :w You'll find there are a lot of knowledgeable people here who will be able to help you with your questions. I think it would serve you better though, if we move this thread to C3 general where the audience is more in tune to your problem.
I'm going to move it there....hang on here we go! :thumb
Block Number??
Is there a 1 in front of 4010207?
The "Corvette Black Book" lists 14010207 block from late 1980 thru 1985.
there is no 1 in front of the number
no there is no number one in front of the casting number and never was , if you look up the casting no. you will find that there are others with the same number asking the same question and not getting an answer please some one find out for me as i have tried countless times.
thank you
thank you
no no 1 at all
there is no 1
Welcome. . . . . . Glad you found us!
:welcome
-Bill
What's the casting date?
What's stamped on the front pad?
...V0717FRT...
Forget the casting number. What you actually need is the stamp above.
V Flint, Michigan engine assembly plant
0717 July 17th date engine was assembled
FRT engine suffix code identifying a 350CID/160hp truck block.
What you have is not a Corvette engine.
:thumb
