LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
Installed a RAM PowerGrip clutch set and had the flywheel resurfaced. Now it appears that in order to get enough throw-out bearing travel to disengage the clutch from the flywheel to shift gears I have to adjust the rod from the clutch pedal to the crossbar to be at the very end of the travel. Which means as the clutch wears down, I am not going to have any adjustment left.
I do not know how much was taken off the flywheel; I assume just enought to resurface it, but do I need to put a shim between the crank and flywheel or get a new flywheel?
Suggestions:
LannyL81
Tucson, AZ
Suggestions:
LannyL81
Tucson, AZ
